Browsing this Thread:
1 Anonymous Users
problems with my 1200 motor |
i got a used 1200 motor, but the motor throw white smoke by the little hole in the valve cover. what is the problem ????
Posted on: 2001/8/27 3:15
Re: problems with my 1200 motor |
From Sydney
Registered Users Contentmaster
Sounds like blow-by. Is any white smoke coming out the exhaust?? Blowby is cause by exhaust gases leaking past the rings and blowing thru the crank case and up to your valve cover hole. Time for a re-build! Scott Davo
Posted on: 2001/8/28 5:07
My old A12 was doing this once, I think I had a faulty PCV valve and it was sucking oily crud into the inlet manifold and blowing smoke out of everywhere. I think I removed or blocked the valve on the inlet manifold to fix it. First thing I'd do is check your compression, as Davo suggested it could be worn rings. James
Posted on: 2001/8/28 6:12
