A15 crank case ventelation ?
From SA
hey
just wondering if the vent on the block is removable as i will be running 40mm webbers and haddent planned on hooking it to the manifold. are there any other options, i was hoping to just block it off with a welsh plug but im not sure if it needs to breath or not? will be to much pressure in the crank case if it is bloked?
cheers Dan
Posted on: 2009/6/9 13:04
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
Re: A15 crank case ventelation ?
From sydney.nsw
put breather outlet into catch can with small air filter so crank case can breath, it may create pressure being blocked off.
Posted on: 2009/6/9 13:19
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
It needs to breathe. The rocker cover vent is for the top end. The bottom end needs to breathe too.
Posted on: 2009/6/9 17:41
From SA
ok but in the case of say a 350 chev there is no ventilation for the bottom end... im stumped ????
cheers
Posted on: 2009/6/10 5:38
Go Hard Or Go Home
Chevy 350 has larger holes between top and bottom ends.
Datsun A-series is designed to have the block vented top and bottom. The block tube is one, and the rocker cover vent is the other.
Posted on: 2009/6/10 6:28
From Geelong, Vic
my L series has the bottom vent blocked off and just uses the top breather, it does have a big gap down the front of the engine where the cam chain goes so that it can tranfer pressure from bottom to top though
Posted on: 2009/6/10 6:32
From Sydney
The reason there is two vents in teh A-series engine is to draw clean filtered air into the engine [via the rocker cover for conventional setup] and then pass any unburnt fumes into the intake manifold via the block breather. In the case of the GX induction setup the flow is in the opposite direction as the block breather connects to the air box and the rocker breather connects the inlet manifold.
If you are running twin webers, I would be inclinded to run both breathers to an oil catch can, as suggested by Bige.
Posted on: 2009/6/10 6:43
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
