Crankangle sensor wires
From Mudgee
Im wiring up a haltech computer to my ca18t, and was wondering if anyone knows which wires on the crank angle sensor are the ground, positive, trigger and home wires??? any info would be great
Posted on: 2009/6/20 23:47
Re: Crankangle sensor wires
From perth
heres a pic of a cas testing circuit
has pinouts listed at the bottom
i have built this and it works so the pinouts must be correct
this also matches factory shop manual diagrams
dazza
jpg  CAS_Test_Circuit.sized.jpg (31.97 KB)
9716_4a3dbf7d7d691.jpg 640X417 px
Posted on: 2009/6/21 6:07
From Mudgee
Thanks that helps but which would be the trigger and which one the home wire ??
Posted on: 2009/6/21 7:29
From perth
pin 1 gives a pulse every 180 degrees
pin 2 gives a pulse every 1 degree
pin 3 is 12v ign
pin 4 is earth
Posted on: 2009/6/26 13:00
Not too shy to talk
From adelaide
I have been using wiring diagrams from microtech
http://www.microtech-efi.com/downloads/22.pdf
Posted on: 2009/6/26 13:18
