Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Engine run on after switch off
1200rallycar
Posted on: 2009/8/5 12:21
Whats the typical cause of this?
the excuse im telling dattogal (her car just doenst want to stop) is wearing thin.... please help save me from spousal abuse! ![]()
#2
Re: Engine run on after switch off
superbin
Posted on: 2009/8/5 12:31
Not maybe timing to advaced?
#3
1200rallycar
Posted on: 2009/8/5 12:36
actually yeah that would be consistant with the fact that it deosnt start very easily when warm also
#4
WhiteSedan
Posted on: 2009/8/5 12:49
Run on or dieseling could be from being too lean, also by timing too advanced or hot spots causing it to fire and keep running.
A later model carby has the ant-diesel solenoid so you can run leaner without running on.
#5
bfunkdlux
Posted on: 2009/8/5 13:14
hey mate
depending on the carby as white sedan said the anti dieseling solenoid maybe inop but the fact that it doesnt start easily when its warm makes me think its flooding which would prob be from needle and seat not sealing properly, or the floiat height is set wrong, causing the bowl to overflow and run into cylinder when swithced off, or your outlet check valve aint working properly put a carby kit thru it and check the float height , should fix this
#6
Posted on: 2009/8/6 3:35
did you say it was trying to run away from her... i would
#7
Posted on: 2009/8/6 4:01
A common cause is idle speed to high: leaking throttle shaft, or incorrect adjustment. These air leaks cause dieseling problem with 1970s cars due to lean mixtures and timing settings -- as emission controlled cars have.
