Wanted: CA bits perth
From perth
hi guys
need some stock CA18DET(S13) bits as follows:
turbo discharge pipe (the steel one) with rubber elbow and clamps
boost control hard line
top manifold heat shield
air flow meter
afm to turbo intake pipe
std s13 airbox
triangular manifold support bracket
thermostat housing
alternator bolt
pcv pipes
rocker cover to intake pipe
cold start to manifold pipe
any help would be appreciated
dazza
Posted on: 2009/8/22 4:46
Re: Wanted: CA bits perth
From Adelaide
Hey Mate,
i have the stock airflow. $30 im in adelaide, i can post it for 6bucks or 10bucks for registered
Ben_edwards87@hotmail.com
i also got 3coil packs, coil pack loom, 4injectors, flywheel
Cheers,, Ben
Posted on: 2009/8/22 5:04
Hey Dazza I know some guy who has a couple of afm for 10 each. He has 3
Posted on: 2009/8/22 7:19
From Geelong, Vic
might have the manifold support bracket. threw a couple of them in the scrap bin a little while ago though
Posted on: 2009/8/22 8:57
From Mandurah, Western Australia
I did have a stock air box, which I did not use as I got a permit for the pod filter. If I still have it, you can have it.
Have the pipe in the pix, is this one of the ones you are chasing?
Will have to check the old mans shed.
jpg  DAZZA.JPG (29.19 KB)
2484_4a8fc476c165d.jpg 400X300 px
Posted on: 2009/8/22 11:13
From perth
thanks ben looks like bailz has the afm sorted
bailz: can you grab all 3 afm? for $30 ones gotta be ok, yeah? if you need the cash upfront let me know
nick: be good if you had one (did your wheel arch come yet?)
jarrad: yep thats one of em. airbox would be awesome if you have it (have you got that photo uncompressed?)
thanks again guys
dazza
Posted on: 2009/8/26 11:42
Have got that photo un compressed, but it was not that big to start with. Have also got some others of CA in Silvia which could be helpful. Send me your Email and I will forward them.
Still yet to go and check the shed for the air box
Posted on: 2009/8/26 12:17
From perth
thanks jarrad
Posted on: 2009/8/30 7:11
From perth
cmon guys most of you will have ripped this stuff off
Posted on: 2009/10/19 13:05
