Browsing this Thread:   3 Anonymous Users
« 1 ... 80 81 82 (83) 84 85 86 ... 96 »
Re: Super Bee KA24DR Sedan
From Snohomish, WA USA
Roadkills General Mayhem has wire mesh. Don't think I can put the headlights behind it though. Maybe the fog lights. I'm switching everything over to LED. You can get aftermarket headlights with bulb inserts now so I'm going that route.
jpg  IMG_20170316_153340.jpg (76.12 KB)
39_58cc0359692bf.jpg 699X412 px
Posted on: 2017/3/17 15:41
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Eaton M62 SC 10 lbs. Boost / 150hp Progressive Nitrous
Ford 8.8 Posi/4.11
you could bend the wiring like a basket or wire tray design
so its a convex shaped setup that way it clears everything
or space it forward with some support arms like basket below
http://stainless-steel-fittings.brass ... _steel_welded_baskets.jpg
a cool finish
http://d3d71ba2asa5oz.cloudfront.net/ ... -ss%201.8mm%20blk%20z.jpg
bending is easy as you know
https://is.alicdn.com/img/pb/213/192/2 ... z-myalibaba-web5_6244.jpg
with your creativity you can do it!
Posted on: 2017/3/18 2:00
Well for now I've decided to put the grill back on.
We've had our first nice day in probably over a month so I'm going for a drive as soon as the roads dry up.
Need to break in the motor.
Posted on: 2017/3/19 16:17
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Drove it yesterday and found out I had a vacuum leak between the carbs and supercharger so I pulled the whole thing out today and resealed it with a new gasket. Didn't get a chance to drive it again and it looks like rain again tomorrow. Waiting for another nice day to come around.
Posted on: 2017/3/21 2:01
'73 2 Door Sedan
Ford 8.8 Posi/4.11
Still haven't raced yet. Last weeks race was rained out. Gives me more time to work on the car to get it ready for sure. Still haven't sprayed any nitrous on the motor.
So the car is geared for the 1/8th mile and last year's 1/4 mile run just left me falling flat at the end of the race. 113 mph @ 11.78 tells me that my launches are good but my finishes are not. So I ordered up another set of rims and some taller tires. M&H 26" Slicks. Getting them mounted tomorrow. Should fit under the wheel wells nicely.
Should improve my top end speed and times. Will have to probably adjust the progressive nitrous system.
jpg  IMG_20170411_211443.jpg (129.67 KB)
39_58eda9d8c9b2a.jpg 700X1244 px
jpg  IMG_20170411_211622.jpg (107.89 KB)
39_58edaa390a6ea.jpg 700X1244 px
Posted on: 2017/4/12 5:26
'73 2 Door Sedan
Ford 8.8 Posi/4.11
One Fender done. One more to go.
Had to manipulate the fender on the front and back down on the bottom. Took about an inch out on both sides and feathered it up. Took the hump out on the inside upper part of the fender. If you don't know what that is take your wheel off and look up underneath. hopefully we'll have this project done by the end of the day.
jpg  IMG_20170412_142715.jpg (49.29 KB)
39_58ee9c4765815.jpg 700X393 px
Posted on: 2017/4/12 22:37
'73 2 Door Sedan
Ford 8.8 Posi/4.11
From Biloela, Sunshine State
Nice Datsa. Can't wait to see what the improved times will be!
Posted on: 2017/4/13 4:10
Thanks!!!
Well I'm done. Car looks meaner.
Looking for good weather for some more test drives. We've had record rain here in Seattle.
It's getting Old!!!!
jpg  IMG_20170412_215906.jpg (58.40 KB)
39_58ef0626b5ede.jpg 700X351 px
Posted on: 2017/4/13 6:03
'73 2 Door Sedan
Ford 8.8 Posi/4.11
I see function over looks. Get on track already lol
Posted on: 2017/4/14 9:41
Yesterday I sprayed 185hp on the motor. Not 175 but 185. I dropped my .063 jet while installing it and lost it somewhere down in the abyss of my motor so I threw in a .064 jet. The wet pavement didn't help other than a long burnout.
Pulling the alternator today. It's going tits up. I noticed low charging yesterday fluctuating between 12 and 12.5 volts. Going to take it in and have it tested but I had them order me a couple different options. KA 240sx alternator is 80 amps and a VG Maxima is 90 amps but a heck of a lot more expensive. Doubt if I really need the 10 more amps.
Having a slight fender rub when turning on the new tires so I need to do more work.
Also, need to install a second return fuel line for my 1 gallon stand a lone tank for the nitrous. I have a return line in the trunk to keep the pump cool but but I have been having to initially prime the fuel soliniod on my nitrous setup otherwise my car will run lean on the nitrous and I get a backfire. If I run the return up at the solenoid, this will solve my problem.
Don't think I'm going to make Pacific Raceways tomorrow and most likely it will rain.
Posted on: 2017/4/14 17:10
'73 2 Door Sedan
Ford 8.8 Posi/4.11
