« 1 ... 84 85 86 (87) 88 89 90 ... 98 »
Re: Slotting a L rectangle into A hole- no whoring please, no off topic, on topic ok!
From Boredomville Melbourne
That support bracket went missing on our 3 day install of the L lol.
that bar is to hold fan in place, the outs step around shroud. Was easier to hacksaw than angle grind at 11pm the night I made it. Just not nearer
Battery tray is handy place to store a beer
Need to chop it out when I get better at angle grinding
Posted on: 2012/9/24 6:26
Was B110 Sedan: L series and 5 speeds, the way they should have been
Now A10 Stanza: L series and 5 speeds...
From Geelong, Vic
what do you mean when you get better at angle grinding? you dont need your inner guard intact anyway
Posted on: 2012/9/24 7:58
Well all in too late to start car and burn the system
Top hose is mix of two but bottom one is a slightly trimmed and twisted 6cyl Ford econovan or something. Perfect almost fit. Shouldn't collapse
But 2 drama
1- dropped the socket wrench off rad support and it Jammed between core and block. Stupidly I went to grab It and Jammed it worse, denting two fins. Hope no leaks under pressure.
2- had to space grill off the mounts as pushed the fan blades onto some part of rad when turned it on to test fan. I tested fan clearance at every stage to make sure of these issues.
Pics
Posted on: 2012/9/25 14:44
Well a magic man fixed my manifold. He yearly deserves a medal
I will let the pics do the talking. Sikyne I love your work
Oh and my favourite .... Trumpets
Posted on: 2012/10/2 10:43
Sikyne cut the old pipes off and put new ones in with trumpets. The longer runners are radiused and the short hoses make it stiff so no need for bracing. The turned lips also mean chances if hoses piping off are almost non existent.
Magic
Posted on: 2012/10/2 10:46
From Armidale N.S.W
Looks cool. You should spend a day tidying up all the wiring and getting it all in some nice insulation. Would smarten it up and reduce ya dramas trust me it made a big difference in me ute.
Posted on: 2012/10/2 11:28
73 1200 wagon CA project
80 1200 ute Full resto, Ca18det Project.
76 1200 Ute A14, Daily, Soon L18 5 speed.
Elecs and me not so good Andy. That's tidier than it was before
Posted on: 2012/10/2 11:51
From Ballarat Victoria
Cheers Mik, Glad you like the improvements.
Be good to see how it performs compared to whats on the engine now.
Posted on: 2012/10/2 13:40
VIC DYNO HIRE
Servicing motorsport professionals
& enthusiasts
Well not huge updates but getting stuck fixed as they pop up. Fixed leaky hose. Used a newer bottom hose up top and smeared a little silicon on the water outlet.and a better hose clamp. No more leak along edge of rocker cover and onto got extractors. Mmmmmm burnt coolant Smell.
Also that rattle got worse it disappeared for a wile after putting button clutch in and came back ffs.
Well I thought no spare box or clutch what bad timing. Then heard the rattle. Thought let's see its not some thing else.
Well pushed down in alt to look deep in bay lightly. Noise disappears. repeated 3 time same result. Not alt. Tried 3 thinking it was dodge bearings in all my spares. But was the piggy made mount. Finally broke after all this time.
The weld snapped through made heaps if noise. He said same happened to him a few times lol.
see the hair line crack in welds.
So I cracked open the mig (gotta love that even though need to practice more_ a lot more ) and plated it top and bottom with spot Welland attempted beads. Poor attempt.
Hope it holds for a little while
I did grind done kg them back before painting
Posted on: 2012/10/22 13:14
My longer term plan is to use the stock alt. Bracket and bolt it to some 6 or 8mm plate and then bolt that to the AC compressor mounts.
Alt on L is usually on drivers side bottom. Mine hit the battery test and chassis rail. So piggy have me his home made bracket.
Need to flip the stick price up side down to work. The red coloreds in bits are to be ground out so alt can.pivot on the mount like stock.
Comments on idea? at least I drew template of the base plate mounting points for future use.
If I had the other type if Mount that's hollow in middle could tad a better Bosch unit from Ivan.
Posted on: 2012/10/22 13:21
