Browsing this Thread:
1 Anonymous Users
rear shocks question |
Quite a regular
From Houston,Texas. USA
Hello gang,to lower the rear of my coupe about 2 inches using blocks will i need an special kind of shocks to make up for the shortened travel? and what shocks are you guys using?
Posted on: 2001/9/29 12:04
Re: rear shocks question |
From Castro Valley,CA USA
On a coupe, the rear lower shock mounts will not move if you lower your car with blocks. Only the axle will move closer to the car. Your question applies to sedans, as the rear lower shock mount is on the axle, or to both if you dont use blocks and dearch the leafs. Angelo
Posted on: 2001/9/29 7:57
What about a dearched rear end (spring dearching),if I use the original shocks,there will be no travel and the shocks will be like a rock,way too hard,as I am experiencing. 2 inch lowering needs shorter shocks,any sources?
Posted on: 2001/9/29 6:06
nah you wont need shorter shocks with blocks coz the blocks just move the diff up on a coupe and ute, not the mounts. new shocks and shorter bump stops will help out though. however if you reset the springs it will be even better again Justin
Posted on: 2001/9/30 12:18
I will answer my own question ,I found shortened shocks for my car ,new ,40 dollars,and will work excelent with the 2 inch droped suspenssion.
Posted on: 2001/10/2 6:27
the shortened shocks will only work effectively if you have reset the springs. because the lowering blocks dont move the spindle that the shock mounts to on the plate underneath the diff. Justin
Posted on: 2001/10/3 4:55
You are right,and that is what I have,I took off the stock springs and took them to a spring shop for reseting ,now being 2 inch lower than regular. I reinstalled them in my car with the original size shocks I had from before reseting the springs and the suspenssion has no effect,and after a bump, the shocks (stock size) tend to swing upwards because they try to extend to its fullest when ever posible,making a bouncing effect after a depression on the road. I got the shorter ones but I have not installed them as of yet. I should expect better performance,I hope,or am I wrong? experts,say something. Thanks.
Posted on: 2001/10/3 7:39
From Near Bundaberg QLD
I know this is ancient history, but what were the shorter shocks that you got jamiecidpedro?
Posted on: 2015/1/31 3:06
Thanks, Sam-U-El/Racer135 --------------------------------------------- 4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
So if you reset your leaf springs you need shorter shocks? I have reset leaf springs on my 1200 ute and I just bought replacement KYB shocks from eBay. I hope I didn't waste my money. http://www.ebay.com.au/itm/3211437756 ... _trksid=p3984.m1439.l2649I wanted KONI's but the KONI 80-1904 shock from the VW Passat (to fit the 1200 ute) are very hard to find.
Posted on: 2015/1/31 9:45
---1976 B120 "THE GENERAL REE"--- Former build---1980 B120 Vanilla Ice --- current build
