clutch cable, having probs
From Wellington
I,m having a fue probs conecting the clutch cable and think I may be missing a part.
The cable passes threw the hole in the bell housing, am I missing a bush or something that fits in the hole first. With it like this there is no way to adjust up a clutch peddle.......Thanks in advance....
Posted on: 2/8 2:52
Re: clutch cable, having probs
From Seattle, WA USA
Online
There are two size bell housing holes. You only need a bushing if your cable is the small size and your hole is large.
Adjustment is done elsewhere: On transmission: 3-4 mm play. Inside: pad height (139.5-143.5 mm from floor). Then check pedal free play -- it must have free play to avoid burning out the clutch -- check with fingertips). Pedal play is 11-15mm
If you just changed the transmission you may have the wrong throwout bearing carrier, which makes it impossible to adjust the cluch to spec.
Posted on: 2/8 3:48
From Wellington
Looks like ive got a larger hole, can I buy a bush or do I have to have this made. Maybe I will have to get a new clutch cable to fit the hole. I think I have the ajustment correct as a fitted a prop in the hole but this wont last.....
Posted on: 2/8 3:58
Online
I theorize you can by a bush. Look at the ones your local hardware store has the are just generic bushings. You can find one that's close and grind the length down.
Or just go to the wreckers and buy the right cable.
Posted on: 2/8 4:51
From Southern Highlands N.S.W. Australia
Or your local Nissan/Datsun dealers parts counter.
The 1970 to 1973 model 56 gearbox used the smaller hole while the 1974 & later 56A gearbox used the larger hole.
The clutch adjustment is done where the cable passes through the firewall.
Posted on: 2/8 13:00
Love your Datsun.
Treat it well.
From Wellington
Great thanks for this....
Posted on: 2/8 20:33
From South Africa
I had this problem when i fitted my later year 5sp to my 1200,
Problem was solved by machining a very simple ally bushing with small lip, so the smaller cable couldnt slide threw the large whole in the box...
Posted on: 2/8 20:41
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
From Nyngan, nsw Australia
if you don't have any luck with nissan...il check later to day mite have a spare in the box of goodie...there the same as 120y's
Posted on: 2/9 3:02
life is good if you dont weak'en,.....
From NZ
A suitably sized large washer from a hardware store works fine too.
Posted on: 2/9 10:08
1200 Coupe Racecar, mid-mount A13, C/R 56A g'box.
Previous Datsuns: B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.
