#1 Dual SU's verses single DCOE
edp Posted on: 2010/3/2 16:32
I'm wondering if theres any advantage of running a dual SU/Hitatchi setup on an A15 vs. single DCOE on a Canon manifold? Any of you guys run the duals? I've got a dual weber manifold but its not going to fit well at all so I was planning on running my single canon/DCOE setup but am interested in finding out more about the SU setup.
#2 Re: Dual SU's verses single DCOE
ddgonzal Posted on: 2010/3/2 19:44
No great advantage. In both cases you are feeding two cylinders with one carburetor bore.
The Hitachis are extremely simple and easy to tune. Also has a built-in balance tube for vacuum advance and vacuum brakes
The DCOE is well-known and will require no syncronization since it is single carb
I would fit whichever one you like the looks of.
#3 Re: Dual SU's verses single DCOE
Dundee1000 Posted on: 2010/3/3 0:29
and because you have access to the canon manifold, coz we don't have them over here..
the SU's would be nice for mild street engine..
the DCOE/DHLA leaning slightly towards more performance..
#4 Re: Dual SU's verses single DCOE
edp Posted on: 2010/3/3 3:07
Thanks guys. I thought I'd heard the DCOE was temperature temperamental - i.e. cold /rough running vs. the SU's, any truth to that idea? that was my only real concern - other then I always thought dual SU's would look pretty cool
#5 Re: Dual SU's verses single DCOE
ddgonzal Posted on: 2010/3/3 5:33
I've always heard lots of rumours about DCOE and also about SU-type carbs. It seems none of them are true.
The factory Datsun twin carbs use a water heated manifold, so the temp should be even.
#6 Re: Dual SU's verses single DCOE
edp Posted on: 2010/3/3 6:06
guess I'll stick with the single DCOE since you sold your SU setup & I cant weasel that out of you somehow. I still think dual SU's would look cool on that A15 though.
#7 Re: Dual SU's verses single DCOE
Fenix_Longbow Posted on: 2010/3/3 7:55
I had twin sidedraught webbers (45mm) on a series 2 Astron engine out of a magna over here, i ended up using a synchronisation setup from an Alfa, after that it was needing a tune every 6 months instead of every month :). It just comes down to your tuner... They are a Dime a dozen but when you find a decent tuner, stick with him, cause they are hard to find. Well, around my way they are anyways :)
