Datsun B310 wtf?
From Atlanta, Georgia
I've got a few loose harnesses that are laying around. I can't seem to find what they go to. There's nothing around the area of the harness that's unhooked. Any ideas as to what these may be?
First is under the dash drivers side near the fuse box.
Second is under the hood near the battery. It looks similar to the alternator signal wire, but it's not.
Posted on: 2010/3/8 20:00
1981 Datsun B310
1973 Honda CB175 K7 Cafe
Re: Datsun B310 wtf?
The one under the hood is a fairly common one, is used for water pumps, thermo fans, signal wires, etc... Dont really have any advice on the under-dash one sorry
Posted on: 2010/3/8 22:27
Well, I know where to start on the under the hood one. As far as the under dash one, everything critical seems to be working so I'm not too concerned at the moment.
I just figured it has to be done some time :P
Posted on: 2010/3/9 2:49
1981 Datsun B310
From Vancouver, Wa
the connection under the hood might be a condencer for radio noise, the one under the dash is most likely the interlock unit, it's to check if your getting a good connection to certain items of the car such as seat switch, seltbelt switch, neutral switch (for an automatic transmission) & warning buzzer.
Posted on: 2010/3/9 4:53
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
Well that would make plenty of sense. Since under dash one only has about 4 wires to it. Only thing is, theres nothing to hook it up to. hmmmmmmmmmm...
Posted on: 2010/3/9 5:03
1981 Datsun B310
This is why you hate the guy that takes all 'unnecessary stuff' off his car, then sells it to somebody else.
Posted on: 2010/3/9 5:50
Yeah, the previous owner totally screwed it up. The interior is trashed, AC compressor is wide open and most likely dead by now, dash is town up and half the dash assembly is missing etc. My sway bar is also bent up on the front end. I cringe at the thought of of what that guy did to the car before he sold it to me.
Posted on: 2010/3/9 6:42
1981 Datsun B310
