s13 struts
From dominican republic
hey guys i just decide to mod my ute and wanted to know what i need to do to fit s13 strut on my ute or should i shorten the stock ones please specify well because i dont know what to do
stock and shortened
http://img294.imageshack.us/i/strut24.jpg/][IMG]http://img294.imageshack.us/img294/2995/strut24.jpg[/IMG]
s13`s
http://img684.imageshack.us/i/y9xee7urabxv.jpg/][IMG]http://img684.imageshack.us/img684/3647/y9xee7urabxv.jpg[/IMG]
a pic i saw on this page
http://img193.imageshack.us/i/strut36.jpg/][IMG]http://img193.imageshack.us/img193/6784/strut36.jpg[/IMG]
Posted on: 2010/3/11 21:27
Re: s13 struts
Quite a regular
From Taradale; NZ
why do want to do that, is it for brakes or adjustability. The issues you'll hit are the bottom ball joint hence think may need customised control arm.
Posted on: 2010/3/11 22:39
No problems, only opportunities
Re: s13 struts
i wanto to lower my ute and whant better brakes but i not very familiar about what are you saying bottom ball joint whats that??? and the lower control arm?? i dont know those parts
please i need a really good explanation of all i need to do
thanks
Posted on: 2010/3/11 22:44
Re: s13 struts
help pleaseeeeeeeeeeeeeeeeeee!!!!!!!!!!!!
Posted on: 2010/3/12 2:51
Re: s13 struts
hey
steering linkage can be found in tech wiki
http://datsun1200.com/modules/mediawi ... hp?title=Steering_Linkage
Its a big job and will take time, will need custom parts. I was and still thinking about doing this setup, my list was
s13 coilovers + hubs/knuckes
s13 outer tie rods (need to re-thread inner rod bolts to different size)
r31 control arms (need to drill out cross member for bigger bolts
r31 castor rods (cut/shorten)
re-drill sway bar holes
Posted on: 2010/3/12 8:48
Re: s13 struts
From SE Melbourne
Shorten original struts, ask around about the bit of metal plate someone here has made up to make it possible to bolt S13 brakes to original struts, save weight, save time and make it easy on yourself.
Posted on: 2010/3/12 12:09
Mildman, Datsunless
Re: s13 struts
Quite a regular
From Taradale; NZ
Its reasonably well explained in tech wiki. http://datsun1200.com/modules/mediawi ... .php?title=S13_Strut_Swap
Go there first, might also want to familiarise yourself with the various parts hanging off the macpherson strut.
Posted on: 2010/3/12 12:19
