Taken from another thread:
Let me understand, ..... the tuner plumbed the vacuum line to the distributor straight into the inlet manifold so that the distributor will see full manifold vacuum at idle & therefore will have full vacuum advance, ..... while idling. Right? Well there goes your 5 degrees of initial advance straight out the window. It would seem that the tuner has fallen for that old trap of assuming that he knows what he is doing & those clever little Datsun engineers were complete & utter morons when they designed that "ported vacuum" fitting on the carburettor. He got that one back to front. This fitting allows the distributor to see manifold vacuum at all times except when the throttle plate is closed. At engine idle the distributor bobweights have been returned to the 'no advance' position by their springs & the vacuum diaphragm has no vacuum signal so it too is in the 'no advance' position & that's when you get your initial advance of 5 degrees.
Having it hooked up to 'ported' or 'manifold' vacuum won't make any difference when it's WOT (no vacuum)... which is the only time when it pings badly
(when set to 5 BTDC and vac advance connected to the carb port)
