Z24 action
Quite a regular
From ipswich
has anyone had any experience messing with these engines? ive thought about cam, carbs, valve springs, extractors and exhaust you know the usual stuff but is it worth supercharging them? if so whats the best charger? SC14? can they handle boost?
i have absolutely no idea when it comes to superchargers can an eaton M90 be used on a 4 cylinder? they are cheap as chips on US ebay.
Posted on: 2010/5/3 1:09
1980 1200 ute SR20DE project
1992 N14 pulsar SR20DE
1986 navara king cab 2wd
Re: Z24 action
From Geelong, Vic
apparently the heads on them arent to flash, but it you are going to oush some boost into it that wont matter as much
could always just get the full injection and turbo setup from a Z18et and throw it on. should all bolt on then you just have the basic turbo plumbing, fuel, air, water, oil etc. stock tune might work, but an aftermarket computer wouldnt be that hard to set up. or go straight gas like on stu's z18/20 turbo 120y
Posted on: 2010/5/3 1:24
Re: Z24 action
Quite a regular
From ipswich
interesting...ill have to investigate this option as i have a T25G lying aroud somewhere and gas is also new to me
Posted on: 2010/5/3 4:28
Re: Z24 action
From Ballarat Victoria
I dont know much about Z24`s but i know your avitar is a big distraction!
Posted on: 2010/5/3 5:03
Re: Z24 action
Quite a regular
From ipswich
yeah avatar is gold lol
does anyone happen to have any Z18ET gear lying around?
Posted on: 2010/5/3 5:26
Re: Z24 action
Got an EFI inlet manifold somewhere. sold all my forged bits years ago.
Posted on: 2010/5/3 13:34
Re: Z24 action
From Geelong, Vic
sikyne, i thought you were more into the costumed up asians...like on the cruise
Posted on: 2010/5/3 13:44
Re: Z24 action
Mine is 89 pathie, Z24 also.My automatic choke was stuffed, so I asked wreckers about another carby. They advised me not to bother as all the carby's of similar age were gonna have similar problems. A new carby was around $800 trade price Be prepared, When I pulled the head off my Z24 after cylinder 4 stopped, turned out to be the piston. Hige gaps around the edge. Got a picture somewhere. I'll put it up if I can find it.
Posted on: 2010/6/8 5:18
Re: Z24 action
From Rosewood, QLD
if you happen to find the manifold what kind of price would you be after?
Posted on: 2010/6/8 7:37
1971 B110 sedan project.
2012 Nissan Micra daily.
Re: Z24 action
Not too shy to talk
From St Marys
I had a z24 in my old 1200 sedan, it started of as a z18t but after it died i sourced a Z24 bottom end from the wreckers, threw my z18t head on and away i went. Ended up running 12.9 on street tyres and single spinner! but did break a piston after a while.
Posted on: 2010/6/8 9:15
