+25mm offset
Quite a regular
From brisbane
can anyone verify that for standard dattos you should be running your wheel offsets +25mm
Posted on: 2010/5/3 7:29
Re: +25mm offset
From Adelaide, Australia
Yes
Posted on: 2010/5/3 8:00
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: +25mm offset
From Geelong, Vic
depends on the width of the wheel really, as 6 inch rims with a +25 offset would most definately be hitting the struts
Posted on: 2010/5/3 9:34
Re: +25mm offset
Quite a regular
From brisbane
with 6.5 inch rims what offset would you reccomend not to foul the struts
Posted on: 2010/5/3 10:00
Re: +25mm offset
From Brisbane
i used to have 7inch wide all round with offsets of +10 at front and +2 at rears and all was fine but at full lock my fronts will scrub inside the guards. they were 15's too. stock suspension. hope this helps
Posted on: 2010/5/3 10:28
