SOLD Aus - VIC - Four puck button clutch and std 56A 4 speed SOLD
From Ringwood, Melbourne, AUS
ITEM:
Four puck button clutch and std 4 speed gearbox
CONDITION:
Clutch plate unused, clutch cover and gearbox used
REASON FOR SELLING:
no need for them, need for $$
PRICE AND PRICE CONDITIONS:
$50 + freight
EXTRA INFO:
nope
Melbourne eastern burbs
CONTACT:
Me (Dean) 0407 118 698, PM, whatever
PICTURES:
Clutch (see below), gearbox you know what they look like..
Posted on: 2010/6/14 3:03
Edited by ssskiwi on 2010/6/18 23:23:31
Edited by ssskiwi on 2010/7/2 9:15:47
Deano
Re: Aus - VIC - Four puck button clutch and std 56A 4 speed
From Sydney NSW
Call me a "noob", but how does this type clutch work, they have more grip right? But there is less surface area...
Posted on: 2010/6/14 4:35
Normally the grip is determined by the friction material and pressure plate clamping force. High friction material doesn't need as much surface area.
It also lessens the inertia by having less material (i.e. mass) at the larger radius.
The center is solid to stop any failure of the sprung center (as in a normal street clutch) which means it isn't as streetable due to shudder etc on take up but won't rip the center out due to failure of the springs.
Posted on: 2010/6/14 4:52
Deano
From Freo
is that a standard pressure plate?
Posted on: 2010/6/14 4:55
A15 PSI Project Motor
'72 CB750k,
From Geelong, Vic
bah, not streetable my arse. i drove around with a solid centre clutch behind my L series for a year with no problems. my sprung button CA clutch was harder to drive with due to the extra clamping pressure wanting to kick your foot off the clutch pedal. cant say i noticed any difference in shudder
they are just a little harsher on everything after the clutch
Posted on: 2010/6/14 6:09
I did say "not as streetable"
Everything is streetable..
I had a button clutch in my AWD bluebird with a CA18 and all of the clunkiness of the AWD drivetrain, very definately street driven!
Posted on: 2010/6/14 8:50
Deano
Dunno on pressure plate, anyway to identify them?
Posted on: 2010/6/14 8:56
Deano
Bump and edit:
Clutch cover used and would also say standard.
Posted on: 2010/6/18 23:25
Deano
On ebay now..
click here!
Posted on: 2010/7/1 13:30
Deano
Re: SOLD Aus - VIC - Four puck button clutch and std 56A 4 speed SOLD
SOLD
Posted on: 2010/7/2 9:16
Deano
