Finally I have copper available. Yay!
For those wondering what a shim is for please read
THIS, it explains a little of the technical background. Here is the general gist of their purpose anyway:
These are intended to space the head away from the block hereby reducing the compression ratio, lower compression ratios are beneficial to turbo applications. These can also be used to run heavily milled high-compression heads on standard pump petroleum.
I will calculate costs once numbers have been submitted but don’t worry, it’s looking quite reasonable;
Material thickness availability;0.7 mm
1.2 mm
1.6 mm
2.0 mm
3.0 mm
Basically the prices will be good if there is a MINIMUM order of 5 per material thickness/gauge. So if you want a 1.2 and no-one else wants one the prices will be high. If there are 4 people at 1.6mm and you can settle for a 1.6mm instead of your 1.2mm then that’ll ensure better prices.
I have tried and tested the metal shims which are cheaper but some people fear they will corrode (read back on previous link). The new shim design is much better as I had the benefit of improving them after testing on my rip-snorter A12.
So who is interested in some copper head shims to run more boost or to save that over milled speedway head? Even if you're keen but want to find out costs just say so, it will all help to make the prices cheaper, thus more appealing, thus cheaper etc etc.
