« 1 2 (3) 4 5 6 7 »
Re: Other applications for the a series
You need electrical power to run the compressor?
How about an A12 powered generator. Just use an A15 flywheel to maximise inertia & minimise speed fluctuations.
A belt drive system with the generator alongside the engine will allow the speeds of the engine & the generator to be adjusted & optimised.
Water pump.
An A10 or A12 can be used to run a fire pump or a pump on the dam at a rural property. A govornor would not be required & a simple float switch to kill the ignition when a water tank has filled would be all that is needed.
Aircraft.
With suitable mods an A12 could be used to power a small experimental class aircraft.
I wouldn't want to regard it as a high performance aircraft but people are still building & flying the legendary Pietenpol homebuilt with a Model 'A' Ford engine [1928 to '31] & they not only weigh a ton but produce 40 hp at peak.
A 65 hp Datsun should weigh a lot less & prove quite reliable.
Posted on: 2010/8/1 4:50
Love your Datsun.
Treat it well.
From illawarra, nsw australia
just a thought.
And i havent read the whole topic so dont shoot me if its already been mentioned.
An a series would run a pretty hefty power generator for emergency power supply.
or a hydraulic pump for a stationary crain inside a warehouse or a decent sized shed.
where i used to work in the qaurry there was a vw engine turning a hydraulic pump which was good for freeing up loaded convyer belts.
Both would be pretty simple.
Posted on: 2010/8/1 7:28
datsunless. for now
From Coondle, WA Australia
Sure I could use another a-series to run the a-series compressor, but its a noise issue that stops me there. For ultimate portability sure its the way forward, but thst not my goal here.
Just looking for a huge output setup at low cost and low noise preferably.
Need to do some more research on electrical motor sizes and gearing options.
An as for a generator, hmm didnt think of that. Should be able to make a good size generator for heaps less that the equilivent "off the shelf" item.
Hmmm, put that one on the back burner for a later project...
Posted on: 2010/8/1 14:25
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Ringwood, Melbourne, AUS
Just saw this: http://beeoneoneoh.wordpress.com/2009 ... ore-datsun-a6-powerhouse/
Now that is lateral thinking for what one can do with an A-series..
Posted on: 2010/8/20 12:59
Deano
I remember seeings this a while ago.
Dont get me wrong A+ for ideas and effort, but other than a "just cause i can" project, does it have a purpose?
As in what application would be be better for over runing an A12 (complete engine)?
Nice job reguardless though
Posted on: 2010/8/25 12:58
FIREWOOD CUTTING SAWBENCH
This thing is scary dangerous, no guard or emergency stop switch! I prefer the hydraulic splitter for a firewood cutting but this is much quicker I guess. Good effort. Starting bid $300.00:
"THIS IS A POWERFUL DEVICE THAT HAS BEEN USED TO CUT MANY LOADS OF FIREWOOD!!"
There was also a bus alternator testing station that utilized an A12 as a powerhouse, I have pics of it somewhere.
jpg  Wood Saw A12.jpg (196.90 KB)
7952_4ccbf866e1c9b.jpg 912X684 px
Posted on: 2010/10/30 11:50
Posted on: 2010/10/30 11:53
From Townsville, Qld
Why not just make the exhaust hairpin back and forth to increase pipe length and sound absorbing capability and run a muffler? not like peak hp is essential here since it's only going to be working on a limited rev range
In unrelated text any bike guys giving me a speel about me wanting to run bike mufflers on my ride on are going to cop a smack in the face
Posted on: 2010/10/30 14:03
That is the sort of inguinety that i was thinking about guiys when i first posted the question.
The wood processor that I am planning in my head (with all the spare time I have) is not quite as brutal, but much the same essectially. Ill have a slide bench or use a swing arm for the blade, oh and a much bigger blade than that. And trailer mounter for ease of use.
I have to give the guy credit for that. Its a nice piece of home engineering. Sure it wont compy with any aus std, but it doesent have to.
Posted on: 2010/11/2 6:32
A-series in there?
Who can guess the machine?
jpg  A-series.jpg (16.53 KB)
7952_4e277a580ff1e.jpg 400X300 px
Posted on: 2011/7/21 2:01
« 1 2 (3) 4 5 6 7 »
