width between 1200 leaf springs ?
From Ashmore Gold Coast QLD
well I am upgrading my diff before i kill it , I need to know the distance between the CENTRE of the leaf spring as I will be welding the new spring hangers on my diff to suit a bolt in application for A 1200 , as my rails have been moved in 3" either side , anyone interested in the diff the specs are as follows . VS commodore narrowed to 1305mm flange to flange VS rear discs and calipers with braided hoses , 28 spline mini spool 4.11 gears 5 stud ford or 5 x 114.3mm also has a brand new TA performance alloy cover that is a girdle has 3" long 1/2" studs works very well .Done approximately 3000 km also has all new bearings through out . will be painted black upon sale
http://www.youtube.com/watch?v=zVZ2_5GxB8U
so can anyone help with a measurement thanks . some pics as fitted without cover.
Nick 0409 255 322 .
jpg  Picture 0002 (Small).jpg (56.27 KB)
3388_4c4e986078b98.jpg 640X480 px
jpg  TA_1802 (Small).jpg (20.57 KB)
3388_4c4e98e69032a.jpg 459X480 px
jpg  Picture 320 (Small).jpg (53.72 KB)
3388_4c4e99275e099.jpg 640X480 px
jpg  Picture 260 (Small).jpg (61.94 KB)
3388_4c4e9947b9d04.jpg 640X480 px
Posted on: 2010/7/27 9:31
Re: width between 1200 leaf springs ?
From Geelong, Vic
970mm according to my sedan
Posted on: 2010/7/27 9:44
970mm is that from the centre ie the locating pin to pin .Need to know thanks for your help .
Nick.
Posted on: 2010/7/27 9:51
From Geelong, Vic
thats from inside of one leaf to outside of the other, so same as centre to centre
that was measured off the leaves at the back hangers
was going to measure straight off the wagon mounts but its too close to the ground
Posted on: 2010/7/27 10:04
Thanks dude I knew I could count on you .
Nick
Posted on: 2010/7/27 10:49
