PCV valve fitment onto sidedraught carb manifold?
Can a PCV valve be fitted so it's is fixed vertically and upright into a manifold runner? As opposed to how it is typically fitted (sideways into the inlet manifold).
I fitted one trying to address my blow-by issue and decided to plum into the runner (hole existing) to extract the rocker blow-by. I was intending to find a sidedraft carb housing to plum the crankcase vent into as the two feeds from crankcase and rocker was too much for the single PCV valve.
Anyhow when I fitted the valve it clicked a few times as the ball valve was getting knocked about with the differeing vacuum/throttle, is this becuase they don't like to be fitted facing upright or is it because the valve I have is simply old?
Any advice on addressing the carb operating issue when fitting the vent line as well (carb is essentially running lean on that runner isn't it?)?
Posted on: 2010/7/31 12:36
Subject Poster Date
     PCV valve fitment onto sidedraught carb manifold? clyons8 2010/7/31 12:36
       Re: PCV valve fitment onto sidedraught carb manifold? ssskiwi 2010/7/31 12:54
       Re: PCV valve fitment onto sidedraught carb manifold? ddgonzal 2010/8/1 1:11
         Re: PCV valve fitment onto sidedraught carb manifold? clyons8 2010/8/1 1:18
           Re: PCV valve fitment onto sidedraught carb manifold? ddgonzal 2010/8/1 1:22
             Re: PCV valve fitment onto sidedraught carb manifold? clyons8 2010/8/1 1:27
       Re: PCV valve fitment onto sidedraught carb manifold? Dodgeman 2010/8/1 3:36
       Re: PCV valve fitment onto sidedraught carb manifold? greendog 2010/8/1 7:46
         Re: PCV valve fitment onto sidedraught carb manifold? clyons8 2010/8/1 8:57
