Browsing this Thread:
1 Anonymous Users
A14Sedans project |
From New Zealand
A link to a video of my new motor! I have done around 800kms so far. Body's ruff as but hey shes a work in progress! I will post pictures and videos of the progress as time goes by... http://www.youtube.com/watch?v=TWNlRmp6NOk
Posted on: 2010/8/8 6:44
Re: A14Sedans project |
From The BV in South Aus
Nice. what have you done to the motor?
Posted on: 2010/8/8 7:48
From New Zealand
Engine Specs
Block: A14
1.00mm oversize high comp / flat top pistons H beam rods Lightened & balanced crank with modified oil galleries Lightweight lifters Lightweight pushrods Lightweight flywheel Fast road camshaft (3000 to 8000rpm range) ARP rod bolts Heavy-duty timing chain Adjustable cam gear Whole rotating assembly fully balanced New oil pump etc
Cylinder head: H89
Ported intake & exhaust ( ports have been matched to gasket and ported for flow rather than size ) 3 angle valve seats Up rated valve springs New intake & exhaust guides with tapered ends Planed for compression Polished exhaust ports and combustion cambers
Ignition:
NGK BPR7EIX plugs 8mm Topgun leads GT40 Coil Petronix electronic ignition
Driveline:
5 speed with heavy duty clutch Shorted and balanced drive shaft H165 ute diff ( 4.11 )
Posted on: 2010/8/8 8:20
Edited by A14Sedan on 2010/8/8 10:23:56 Edited by A14Sedan on 2010/8/8 10:25:09 Edited by A14Sedan on 2010/8/8 10:32:56
From New Zealand
Time for an update of the rear suspension. 2" re-set + 45mm lowering blocks with an extra leaf added in to stiffen things up a wee bit.
Attach file: new leafs.JPG (36.87 KB)
Posted on: 2010/8/24 10:27
Edited by A14Sedan on 2010/12/7 0:43:24
From New Zealand
Got the extra leaf made so it helps with reducing axle tramp
Attach file: extraleaf.JPG (47.01 KB)
Posted on: 2010/8/24 10:29
From New Zealand
New ride height
Attach file: new ride height.JPG (52.16 KB)
Posted on: 2010/8/24 10:31
From New Zealand
Picked up some 910 bluebird struts for the front... my plan is to turn them into adjustables.
Attach file: bluebird struts.JPG (50.73 KB)
Posted on: 2010/8/24 10:37
From New Zealand
Still need to buy a coilover kit, springs, r31 shock inserts and s13 camber plates! I brought some r31 callipers.. just waiting for them to turn up!
Posted on: 2010/8/24 10:41
more pics of the rest of the car. nice rear leaves.
Posted on: 2010/8/24 11:54
From New Zealand
My new wheels.
14x7 -4 offset. Im going to change the tyres and fit a set of 195x45xR14
Posted on: 2010/9/23 10:27
Edited by A14Sedan on 2010/9/23 10:58:20 Edited by A14Sedan on 2010/9/24 1:46:45
