Browsing this Thread:
1 Anonymous Users
fuel fire angle & timing advance |
Quite a regular
From Perth
anybody had problems with firing angle in A14 injections? need to know what to set it at. and does the ignition timing advance change if the motor is turbo?
Posted on: 2010/9/7 14:04
Re: fuel fire angle & timing advance |
Registered Users Contentmaster Usermaster
The advance curve changes with a turbo. But the initial static timing is the same. 10 degrees will be fine.
Posted on: 2010/9/7 19:15
