Browsing this Thread:
1 Anonymous Users
45 DCOE wbers on L series manifold |
From Sydney , NSW
Due to a new direction in racing, the 45 webers that have served well in the datto over the years are up for sale.
Pair of complete, perfectly tuned (by Hi Comp Performance in Sydney) 45 DCOE Webers on an L series manifold. For those that will ask ... one is a 45DCOE 152 8F, the other is a 45DCOE 152 5G. Come with custom aluminium bracket to enable centre pull using a standard Datsun throttle cable, NEW anodised ram tubes from EFI Hardware, soft mounts, and custom return spring bracket. These carbs have the chokes machined out so they are true 45mm bore and were set up to feed my L20 race engine. These carbs will start AND idle whilst being as smooth as you can get without injection. They will be supplied with braided line and earls fittings between carbs with a braided supply line/ 90deg -8 fitting. They are set up for a recirculating fuel system so you may have to change fittings around if you run a standard system. You may need to re - jet for a mild engine as these are set up for a big compression engine.
Price $1350 firm - you cannot replace them for this price AND they are tuned and proven.
Pics available to serious buyers.
PM here or phone Jeff 0415 107 090
Posted on: 2011/2/4 10:03
All torque, no traction A division of "My mate's ....." engineering
