Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Pinion oil seal
LOWTECH
Posted on: 2011/4/24 6:58
Does anyone know the differential pinion oil seal number for the h-145? I've got numbers of the seal but it doesn't translate into a part # that I can find. Plus a source if you've got one.
#2
Re: Pinion oil seal
a12datto120y
Posted on: 2011/4/24 9:12
not sure on part number but most things i can get from bursons auto parts for my 120y! just ask over the counter they do special orders some times!
#3
Re: Pinion oil seal
LOWTECH
Posted on: 2011/4/24 18:49
Thanks, but I'm in Los Angeles... Don't think I'll be walking into Bursons..
#4
Re: Pinion oil seal
Posted on: 2011/4/25 5:30
Oreillys, Pep Boys, Rockauto.com, Autozone ... take your pick
Pinion seal Quote: •38189-18000 SEAL-OIL DRIVE PINION
#5
Re: Pinion oil seal
Dodgeman
Posted on: 2011/4/25 7:58
If you are replacing the pinion oil seal in an iron housing H145 then be prepared for a little bit of work.
Here's the proper procedure. Jack up car & remove both rear axles. Uncouple driveshaft & remove differential. Mount differential in suitable stand & remove hemisphere & crownwheel assembly Remove drive flange & extract pinion. After cleaning housing, replace seal. Fit new colapsable pinion pre load spacer & refit pinion. Refit all other parts. Check & adjust as necessary pinion depth of mesh & preload as well as pinion to crownwheel free play. Correct as necessary. Using new gasket, refit differential to rear axle housing. Re-install axles & refit drive shaft. refill diff with oil Run car in gear on jackstands to check that all is well. Lower car to ground & return it to service. For alloy housing H145 1. Place car on jacks or hoist. 2. Remove drive shaft & drive flange. 3. replace seal. 4. reverse steps 2 & 1
#6
Re: Pinion oil seal
Posted on: 2011/4/25 8:12
Fit new colapsable pinion pre load spacer & refit pinion And the pre-load (crush) spacers are NLA... Replacing the seal and torquing to spec worked for me. You'll know if your diff stays quiet.
#7
Re: Pinion oil seal
LOWTECH
Posted on: 2011/4/25 19:16
•SKF Oil Seal #550219 Partsamerica.com $22.99
Partsamerica no longer around... When's the last time you bought any part for a 1200 at Pep Boys or O'riellys? Haven't had much luck lately..RockAuto lists the wrong seal (for H190 and R180)I actually have 3 new crush spacers for the 145 diff, but was hoping to just replace the seal and retorque. Bad Idea? Quote: If you are replacing the pinion oil seal in an iron housing H145 then be prepared for a little bit of work. Here's the proper procedure. Jack up car & remove both rear axles. Uncouple driveshaft & remove differential. Mount differential in suitable stand & remove hemisphere & crownwheel assembly Remove drive flange & extract pinion. After cleaning housing, replace seal. Fit new colapsable pinion pre load spacer & refit pinion. Refit all other parts. Check & adjust as necessary pinion depth of mesh & preload as well as pinion to crownwheel free play. Correct as necessary. Using new gasket, refit differential to rear axle housing. Re-install axles & refit drive shaft. refill diff with oil Run car in gear on jackstands to check that all is well. Lower car to ground & return it to service. For alloy housing H145 1. Place car on jacks or hoist. 2. Remove drive shaft & drive flange. 3. replace seal. 4. reverse steps 2 & 1 Why don't you need to replace the crush sleeve on an alloy diff housing?
#8
Re: Pinion oil seal
Posted on: 2011/4/25 20:30
Partsamerica.com has been renamed to oreillyauto.com
I don't buy many parts as the Datsun is very reliable. But I found 1200 parts there two weeks ago. I would get it from Nissan: * 38189-18000 SEAL-OIL DRIVE PINION Only $8.28 in the 2011 catalog, hopefully they won't have to order it from Japan but will have it in stock.
#9
Re: Pinion oil seal
LOWTECH
Posted on: 2011/4/26 5:43
According to Nissan, that part is out of manufacture. However, they did a search for me and found 8 at a dealer in Tennessee. I was gonna get a few, but he said if I got all 8 I could have them at half price each so I got em all. So if anyone needs one I've got extras.
