I have a professional workshop type vacuum gauge that my stepfather bough from Redex back i the 60's. It's nice & big & works well. One of the things that came with it is an external clamp around the vacuum line & this is intended to cause a restriction in the line.
What this does is dampen out the wild fluctuations of the needle at idle, particularly in a four cylinder engine. Some people use a vice grip to restrict the tubing [but not squash it, blocking the vacuum signal completely. You should see the needle move smoothly when reving up, but not flicker wildly.
Good, now that this is done, disconnect the vacuum line at the distributor & plug it. A Philips screwrdiver of the right size is good for this.
Start the engine with a dwel angle meter connected to the distributor. Standard spec is from 49 to 55 degrees of dwell but I would set it to 49 degrees as the figure will move towards 55 degrees as the points wear over time. Using just feeler gauges is OK, .... just & is really little more than a setting to get the engine started when installing new points.
Next, set the idle to factory spec's using the Tach that you previously connected.
Here's where the vacuum gauge comes into play. While watching the needle, gently screw the idle mix screw in or out. You are looking for an increase in the vacuum figure & with it will come an increase in idle rpm.
Get your best reading & adjust the idle sped to spec's. Repeat the mixture adjustment.
Next, set the ignition to spec's at the nominated idle speed. If revs increase then re-adjust the idle speed & check the timing again. Once this is done, reset idle speed to spec if different from the speed needed to set the timing.
Re-connect the vacuum line to the distributor. Now that these things are right, you can compare the reading on the vacuum gauge to any tech spec that you might have in the vacuum gauge's instructions.
With careful attention to detail, I can get 18-1/2" HG from my stock 1200 engine at 600 rpm at 2,500 ft elevation, where I live. Despite my engine being close to 40 years old, it is in near perfect mechanical condition. You should get a slightly higher reading at sea level.
Oh yeah, all readings & adjustments should be done with the engine at operating temperature.
Posted on: 2011/5/2 15:08
