Trouble starting car (electrical)
From Perth WA Australia
I am after some advice.
The battery is fully charged
The engine runs fine once it is going
Sometimes it will start then it will not
The starter will not turn the engine over, then it will 5 minutes later
Is it the ignition or the resistor. Not big on electrical issues
Please help
Thanks
Tom
Posted on: 2011/7/12 12:31
Re: Trouble starting car (electrical)
From Albany, Perth Australia
it might just be the solenoid...check if it is hot after trying to start it....if so then its stuffed. they can be fixed...sometimes
or could be the brushes on the starter motor, might be best is to take it off and check it out...cant hurt, they are very easy to work on
Posted on: 2011/7/12 12:36
1200 Smerf Mobile
so how did you go thomas?
Posted on: 2011/7/17 11:18
1200 Smerf Mobile
