a novel type of blow off valve - PCV problem on CA18DET
From Melbourne, Australia
so, i have been flooding my motor with oil and it was pooling under my real BOV on the cruise yesterday
today i am reading the service manual for S13, it appears i was using my motor as a blow off valve, as i think there is no PCV valve on my motor.... boost was passing through my motor in one rocker cover, through the sump and out the other, carrying lots of oil with it into my induction system
on the service manual it shows the PCV valve near the inlet manifold on the hose between it and the closest rocker cover, cant open my bonnet until my wife gets home cause that needs adjusting but does anyone have a picture of their PCV valve location on their CADET, service manual just has cartoon style system pics so unsure exactly where valve fits in???
Posted on: 2011/8/15 10:28
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Subject Poster Date
     a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 10:28
       Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 10:34
         Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 10:35
       Re: a novel type of blow off valve - PCV problem on CA18DET levey 2011/8/15 10:58
         Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 12:21
       Re: a novel type of blow off valve - PCV problem on CA18DET oda70 2011/8/15 12:44
         Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 12:50
       Re: a novel type of blow off valve - PCV problem on CA18DET oda70 2011/8/15 12:59
       Re: a novel type of blow off valve - PCV problem on CA18DET oda70 2011/8/15 13:02
         Re: a novel type of blow off valve - PCV problem on CA18DET 1200rallycar 2011/8/15 13:22
           Re: a novel type of blow off valve - PCV problem on CA18DET PIGDOG 2011/8/15 13:46
       Re: a novel type of blow off valve - PCV problem on CA18DET oda70 2011/8/15 13:35
       Re: a novel type of blow off valve - PCV problem on CA18DET tommo73 2011/8/16 0:51
