Hello all.
My name is Tom and I am a new member. I have been lurking for a while. I am planning an A15/5 speed build for my 1969 MG Midget and am making several plans for intake/carb combinations. I found the thread by member TnPshow
A-Series Manifold Templates for Autocad - Come n get 'em. Just what I needed! Except the "members.iinet.net.au"-based links were all dead. Since TnPshow's member email is also from that ISP and since his member profile shows his last post being May of 2010 I don't hold out much hope that he will see this post.
What I am looking for is a copy of the CAD file for the intake and exhaust flanges for the small oval port H89 head. This head was OEM for 1980 A14s in the 210 and I snagged one recently to use on my 1982 A15 build. I plan to mod the factory intake to take a side draft carb of some sort (I have a 38mm Lectron) to get it running and broken in, then I will probably move to a twin HS4 deal. There may be other plans or options if I can just whittle parts out at will. Having the CAD models will make things much easier.
If anyone has the same or similar (later-style intake flange) intake and exhaust flange AutoCAD or Inventor (or DXF or STP) files could I get a copy? I have access to Inventor 11 and below.
On edit, eye candy:
