New forum format or something amiss in my settings?
Hi Techwizards...since the server migration,I cannot see any partitions or borders between individual posts. Is this normal or have I failed no enable a setting on my browser or something?
It makes reading threads a tad difficult is all, maybe I just gotta get used to it.
Posted on: 2012/1/28 1:44
Re: New forum format or something amiss in my settings?
From Seattle, WA
Server migration? I haven't noticed any changes.
Are you going to http://datsun1200.com or something else like www.datsun1200.com?
Posted on: 2012/1/28 2:34
B110 sedan: L series and 4 speeds, the way they were
From adelaide can post trim worldwide
on occasions im havind the same issue usualy once i sign in
Posted on: 2012/1/28 2:41
From Seattle, WA
I wonder if you are seeing the different View Modes:
* Threaded
* Compact
* Newest First
The site "Fast Search" which is supplied by Google switches the View Mode to "compact" and logs me out of the site.
Posted on: 2012/1/28 3:40
Ah thats what solved the issue last time!..tho sadly not this time...tried Flat, Threaded, Nested all I get is this:
Posted on: 2012/1/28 3:54
Couldn't find a "compact" option?
From Seattle, WA
yes, you are seeing the "compact" view. You want to switch to "flat" view.
It's at the top, above #1 post. Click "View Mode", then click "Flat". The page should automatically reload. If it doesn't, reset your browser to the normal settings.
Posted on: 2012/1/28 4:27
all fixed cheers for tha you learn something new every day
Posted on: 2012/1/28 4:40
Found it... thanks again dd!
I was looking in the edit profile settings, wasn't working there.
Posted on: 2012/1/28 4:53
