t28bb identification help please
From Melbourne, Australia
i have a so called "t28BB" here, but want to confirm
went to nissan silvia website but every next post contradicts the last
anyone have an easy way to check, the ID tag is missing unfortunately
there is shaft play in that the wheels can move laterally in the housing, but no movement longitudinally (aong the common shaft)...should i be worried about the condition of it or is some lateral movement accepted as normal?
Posted on: 2012/6/9 1:11
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: t28bb identification help please
Bring it over and check it out with my t28bb
Posted on: 2012/6/9 1:44
Car free
pretty sure bb have 6 bolt turbine housing
Posted on: 2012/6/9 11:20
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
Nope the rear housing size is different but still 5 bolt
Posted on: 2012/6/9 13:30
Car free
are you talking about where the dump pipe bolts to supa?
im talking about where the turbine housing bolts to the chra, should be 4 or 6 bolts
Posted on: 2012/6/9 13:45
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
Yep I was talking rear housing but I've also had a s14 t28 6bolt front housing, and s15 t28bb and is 6 bolt as well
Posted on: 2012/6/9 14:15
Car free
T28 brush bearing
T28 ball bearing
Posted on: 2012/6/9 14:20
Car free
easiest way to tell if its ball bearing is where you bolt the chra to the turbine housing, 360 degree thrust bearing will have 4 bolts and ball bearing 6 bolts like in the picture. i circled the ones im talking about
jpg  housing031.JPG (10.39 KB)
9021_4fd3f76b49e45.jpg 300X156 px
Posted on: 2012/6/10 2:25
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
sweet, mine is 6 bolt, any comments on the shaft play?
Posted on: 2012/6/10 7:04
1200 Coupe Rallycar
well usually as long as it spins freely and there's minimal movement it should be fine, its hard to say without out seeing it. what the compressor wheel look like? not discoloured or anything? are the edges smooth?
Posted on: 2012/6/10 7:52
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
