« 1 2 (3) 4 »
Re: How low is your CA18?
From Melbourne, Australia
yeah i set mine up to be 40mm off firewall as well, allows use of the stock heater (holes through firewall for hoses)
with that clearance you may be able to fit an oil drain at the back of the head as is
50mm is pretty good
Posted on: 2012/7/6 1:56
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From WTB 4 speed 60a & vb10 shell
Worsel any specs on your beast setup?
The oil drain on the back is due to too much volume or pressure on the head or both? Its confusing since there is an option to enlargen the oil feed hole to the head on the RB engines and maybe also the cadet?
Any chance of pics inside the sump to see the baffling setup?
Posted on: 2012/7/6 3:02
During times of universal deceit, telling the truth becomes a revolutionary act, Big Brother is watching you - George Orwell
From MOOROODUC - Victoria
Measured mine
33mm measured next to the throttle cable holder
136mm back flange of the plenum from the main plane of the firewall
about 63mm passengers side rocker cover from the main plane of the firewall
jpg  Engine placement3.jpg (67.95 KB)
8710_4ff64fa73310a.jpg 486X648 px
jpg  Engine placement1.jpg (62.83 KB)
8710_4ff64fba8eb89.jpg 486X648 px
jpg  Engine Placement2.jpg (57.78 KB)
8710_4ff64fcb19467.jpg 486X648 px
Posted on: 2012/7/6 3:42
1200 Coupe (Beacon red)
1200 Ute Auto Silvia in disguise (Shockwave blue)
1200 Sedan (Kermit green)
myself and pigdog both measured (i think) just in front of the ECCS badge on the inlet manifold, not where your photo indicates
Posted on: 2012/7/6 4:09
1200 Coupe Rallycar
there's not much difference at that point ... I think my plenum is almost parallel with the top of the guards (i.e. 33 to 34mm below all the way)
Posted on: 2012/7/6 5:21
From Geelong, Vic
yeah i measured from beside the throttle cable holder about half way along the plenum
that's what my sump looks like, don't have a pic from underneath. but if you imagine the small hump in the sump was just inverted, that's what it looks like
Posted on: 2012/7/7 10:58
whats the theory of just adding wing on one side? did you use baffles?
is the main aim to add more volume of oil for temperature reasons or to stop issues with surging?
sorry but i dont understand the last comment under the pic
Posted on: 2012/7/7 11:42
1200 Coupe Rallycar
From Geelong, Vic
didnt want to add that much so only put a wing on one side. no other real reason. was mainly to just have a bit more oil in there so there is less chance of all the oil getting stuck in the head and destroying engines. no baffling in it
i modified the bottom of the sump to allow it to sit lower. if you have a look at the sump on a CA you will notice there is a small hump at the back of the main hump and its the first part of the sump to hit the crossmember so it stops the engine being able to go lower. i inverted that hump so the main hump goes all the way up to the main flat section. get another 10-20mm of clearance
Posted on: 2012/7/7 14:32
From Logan, QLD
Mine used to sit like this.
Posted on: 2012/7/7 16:41
From Christchurch NZ
I've never sat a CA into a B110. But something I found when I fitted an L20B into a KB310 was the height of the drag link was more of an obsticle to getting the engine low. I sectioned the guts out of the the Xmember to get the tall L20B block down lower in the hole. BUt then the engine sat on the drag link. (It was much worse at full lock too)
So we spend most of a day raising the floor of the (810) sump to get more clearance. (ONly to later discover that the rack an pinion 910 L20B sumps came with the very shape we strived so long and hard to create)
Since CA's came from R&P equipped cars already, It's safe to assume they have this shape too. (To be honest, I've never actually looked closely at the CA sump yet)
A mate of mine who is putting a CA18det into his 2door sedan has done the same thing. Sectioned the center part of his Xmember, and altered the sump to clear the drag link. So as to get the motor as low as poss.
BUT, when the 1st sump was modified, the engine was out pof some early EXA type car. The very early CA twin cam engines had different ports, and no girdle. When he shelved the idea of the supercharger, and bought a complete det engine instead he found that the sump in the pic above hit the girdle. (When We did my L20B sump, we used blue tack to check the crank to sump clearance at bdc)
So While I have nothing really to offer here, thats my thoughts on low low you can go.
Although, NickM tells me that the drag link from a B210 has a different shape to it. And allows a whisker more low-ness.
Posted on: 2012/7/8 0:16
Forced Induction!
« 1 2 (3) 4 »
