WTB: Lowered struts/coilovers 1200/120y
Quite a regular
Hey guys,
I'm sure there is a slim chance of this but thought I'd try anyway before I go buy a coilover kit from Otomoto. Looking at lowering my ute but want to stick to original 1200/120y gear so if anyone has any shortened disc brake struts or struts that are already converted to coilovers let me know
Preferably in NSW
Posted on: 2012/8/7 14:54
Re: WTB: Lowered struts/coilovers 1200/120y
From gold coast aus
there is a post on here using s13 rear coil overs to make some for 120y /1200 struts
i have gone and bought second hand pair rear s13 coil overs that were leaking stripped & cut off the threaded section which is 45.3 mm id just enough to slide tightly over 1200/120y strut
i stripped 120y strut found some inserts 73mm shorter in body length
then cut the section off top of strut where the captive nut is about 50mm below
then cut out approx 65mm section and rejoined the top section with the bottom makeing sure that insert goes al the way in might need washer just under depends on measurments mine was fine
then slide sleave over top and weld just below top so you can still do up insert nut
put springs on and strut top just in middle of welding mine up now
total cost with out camber tops 150 with new inserts
Posted on: 2012/8/7 23:07
Have a chat to member supafatto... Pretty sure he was doing coilover packages?
Posted on: 2012/8/8 0:16
1200 Ute - Mild A12
1200 Ute - Rolling Shell Donor
1200 Coupe - A14 EFI SC
Quite a regular
Thanks for that mate, I do remember looking at a thread where someone used busted s13 coilovers. I'd definitely be happy with a setup like that although I don't have the skill to make that up!
Yeah I have pm'd him but he only makes stuff for larger struts
Posted on: 2012/8/8 6:04
From South east vic
My sleeves you can use for 45mm struts they just need to be centered before welding, I can supply wedges to use to center them until welded into position
Posted on: 2012/8/8 6:44
1200 coupe under construction
