sticky clutch problem.
From Malaysia
can't shift into first or any gears while the engine is running. if the engine is off, i can shift the gear. car has been sitting for while though. not a Datsun 1200, but a civic 1200. any quick fix? a month from now i will rebuild the engine, i just want to relocate the car.
the civic...
Posted on: 2012/8/12 10:45
Re: sticky clutch problem.
From South east vic
Put it in gear and try start it, stomp on peddle a few times, knock on bell housing prob be sticky
Posted on: 2012/8/12 11:18
1200 coupe under construction
From Sydney
Clutch cable not properly adjusted?? Or are they hydraulic?
Posted on: 2012/8/12 11:30
From Boredomville Melbourne
Love it. Had a girlfriend with.one... She hammered that car and being a Honda it took it. Jap mini
Posted on: 2012/8/12 12:12
B110 sedan: L series and 5 speeds, the way they should have been
From Malaysia
they are cable.
700kg ride with a 1.2 liter motor, an awesome platform to begin with. the carburetor is same as b110. the best part of it, there's a 1.6 liter engine from Accord that have same mounting.
will try unstuck the clutch tomorrow.
Posted on: 2012/8/12 13:06
From Malaysia
i shifted into first, start the engine and press the brake and gas at the same time, it works! thanks supafatto.
Posted on: 2012/8/13 1:13
From South east vic
No problems sometimes they bind when sitting for a while, best of luck bud
Posted on: 2012/8/13 6:20
