A15 60A FS
From cold toast
Hey guys, I have an a15 with delorto 40s(which are brand new) porting work redline inlet manifold new bearings mild cam and a freshly machined flywheel, basically a mild rebuilt a15, that I need to get rid of as I've since purchased an sr20 for it. The engine has been dyno tuned in the car it came out of and been run for approx 10hours + run in time. I'm looking for around 2000$ for it as that's what I payed for it.
I also have a 60a standard shift pattern 5 speed that has just had new bearings put through it and had a general check over, everything inside is mint, that I'm chasing 1300$ for.
Im willing to post. Prices are negotiable. And if you purchase both I can do you a good deal, even though it already is.
I need these gone ASAP
Posted on: 2012/8/22 2:33
Re: A15 60A FS
From mandurah
Just out of interest what did the a15 make on the dyno? I havnt got final figure for mine but its was roughly 106rwhp before i put the right jets in it as the old ones were too big and it ran rich
Posted on: 2012/8/22 3:43
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Re: A15 60A FS
From Adelaide
Hi mate interested in the gearbox, would you consider postage to Adelaide?
Posted on: 2012/8/22 13:11
Re: A15 60A FS
if you would post photos of the motor i might be interested.
Posted on: 2012/10/7 9:37
81 1200 ute
73 1200 sedan
