Time to go.
I've enjoyed this car for about 4 years now, I am moving interstate and need it gone.
I don't have the time to drive the car any longer, so someone else might as well enjoy it.
Motor was rebuilt last year, has been driven only a dozen times after run-in and tune.
Stamped A14
1608cc
A15 crank, lightened & knife edged
Big race cam
79mm Mahle flat top pistons, custom valve relief
Oval port head, ported polished
2mm oversize intake valves
1mm oversize exhaust valves
GX intake manifold, port matched
Genuine twin 40mm weber DCOE carbs, rebuilt same time as motor
Custom intake trumpets
Genuine Facet electric fuel pump
Holley fuel regulator
1l surge tank
VL alternator
Battery relocated to the boot
VS/VT radiator (new 12mnths ago)
12 inch thermo fan
4-1 extractors, 2 inch exhaust, great muffler before diff, with 2 1/4 dumped tip
60 series 4 speed box
HD clutch (new with engine rebuild)
Lightweight flywheel
H165 ute diff, 3.9 ratio center (open)
reset rear leaves
front AND rear sway bars
front strut brace
adjustable camber tops
R31 front discs and struts
13x7.5 widened steelies
Nexen cp641, 165/60/13, 80%+ tread all round
twopac white, sprayed before i bought the car
rolled rear guards
escort guards moulded into fronts
some surface rust showing through in bottom of the door sills & bottom of rear quarter
interior is good, carpet is only 5 years old, dash has a crack on driver side corner, dash mat covers it well
currently fitted with aftermarket adjustable buckets, but will be fitting B310 seats for final RWC next week. Rego till January next year.
Probably forgotten a heap of stuff.
Car goes hard, great for hills
$6,500
Contact me for any more info or to organise an inspection
Car is in Varsity, Gold Coast
I'm happy help with interstate buyers also
I'd prefer text during working hours daily, call me anytime after 5.
Leon - 0413516063
photos on photobucket here
http://s97.beta.photobucket.com/user/IAMLeon/library/Datsun%201200
