Weber Carb's and intake setup?
From San Diego,California
Ok I just UN boxed my weber's and went to install them on my manifold and noticed the throtle pull is on the wrong side... so I said ok.. just switch them around.. and still No luck they don't jive with the angle I need. I just bought these so I'll call weber and see if they can send me the ones I need.
Ant help would be appreciated:)
Posted on: 2012/11/19 1:22
Mahalo Victor
Re: Weber Carb's and intake setup?
Can you upload a picture?
Posted on: 2012/11/19 2:13
DGV and DGV are mirror image carburetors.
But you can fit them either way:
* Overpull
* Underpull
Posted on: 2012/11/19 3:22
I'm going to run DCOE 40's,the throttle push/pull is on the Left side of the carb ,I need the Right side.
Posted on: 2012/11/19 4:38
Mahalo Victor
You can do twin sidedrafts various ways:
* Center pull (RH and LH set)
* Twin pull (two LH pair)
* Twin pull (two RH pair)
Posted on: 2012/11/19 4:51
