Anyone need drilling maching done ?
Hey guys I'm a fitter and machinist by trade am looking at some extra work, if anyone needs some machining done e.g drilling axles, mill or lathe work let me know I am located in Campbelltown nsw
Posted on: 2013/1/13 9:07
Re: Anyone need drilling maching done ?
Can you put a tapered hole into things easily enough? I want to run early 45mm strut/steering knuckles with later model balljoints, and afaik the tapered pin is a little bit thicker, so the tapered hole would need to be enlarged (whilst retaining the taper itself) - that sort of thing be any interest?
Posted on: 2013/1/13 10:04
John McKenzie
Pm sent
Posted on: 2013/1/13 10:12
datsun a15 ute
From Geelong, Vic
Jmac, you know you can just use later model 120y or 1200 ute steering arms to do that job. Not to try and steal your business or anything datgx
Posted on: 2013/1/13 10:48
All good mate If he can find a easier cheaper way then all means do it, but my help is there if needed
Posted on: 2013/1/13 10:57
datsun a15 ute
now I'm confused - I thought all the later steering arms on the 120y and utes that 'fit' the larger ball joint tapered pin are also only for the 50mm struts not the 45mm ones? Or are there essentially 3 types of steering knuckles - big and small tapered pin to suit 45mm struts and a third to suit the 50mm struts?
Posted on: 2013/1/14 9:01
John McKenzie
Do you have some pictures of some of your previous work? And what different materials do you have access to?
Posted on: 2013/1/14 9:21
I am the one who made the stainless steel
Scuttle vents and strut covers on the laser cutter, I
Currently making s13 adapter plates aswell but not selling them as I don't want to take
Supafattos buisness. I have drilled several axles to change pcd.
Machine drums, rotors, redrill blank rotors to suit your pcd. Any mill or lathe work I have access to a whole range of steel, stainless, alloys.
Posted on: 2013/1/14 10:24
datsun a15 ute
From Sydney, NSW
yeh those scuttle vents look awesome on my ute datgx heaps better than the steel ones, still have to put the hinge covers on aswell after i get em polished.
might have to hit u up for some strut covers too haha
good work mate.
anyone need some work done he's ya man, very good craftsmanship...
Posted on: 2013/1/14 11:17
Daily: 2000 Holden VX Calais 5.7L GenIII
Datto: 1972 Datsun 1600 L20B twin 40 DCOE Webers
From Sydney, NSW
not the best pic but check out those vents hahaha
Posted on: 2013/1/14 11:19
