Sunny doesn't want to self center. What to do?
From Christchurch NZ
My POS sunny has always been a bit reluctant to self center. After I lowered it, I had a mate do the alignment for me. He said it was the straightest and best sunny he'd done. (He's done a few now)
But it's always been a little bit reluctant to self center. I got knocked out for a WOF for it last time. I completely pulled the suspention apart, and greased the hell out of everything. Then went back for the recheck with standard front wheels. The guy passed it, but said it was still not very good.
It's been a little "loose" feeling, but everything seems to be tight. (No rooted ball joints, or knackered bushings.
So I've tightened up the steering box a little, and now the self centering is heaps worse.
Which aspect of the geometry effects the self centering? After I turn a corner, It doesn't want to straighten up by itself.
Posted on: 2013/2/4 7:24
Forced Induction!
Re: Sunny doesn't want to self center. What to do?
From Sydney
Castor
Posted on: 2013/2/4 7:38
Mostly castor
But also toe-in which is the easiest to check.
Posted on: 2013/2/4 7:39
I might thread up more of the castor rods, and dial a bit more. It should be sweet to drive, but it's not really. I just fitted new front tyres too.
Posted on: 2013/2/4 7:57
Forced Induction!
Try the no-thread method -- it might just do enough. It did on my ute. And only an hours work.
Posted on: 2013/2/4 7:59
From Melbourne AUS
i'd say too much toe-out, but your mate should have checked that
Posted on: 2013/2/4 8:45
1973 B110 A12
Try swapping your front tyres left to right. See if it changes anything.
Posted on: 2013/2/4 9:23
Fronts are brand new.
Did you see my gearbox thread at ozdat Don?
Posted on: 2013/2/4 20:56
Forced Induction!
Brand new doesn't mean anything Bart. I've seen new tyres do this plenty of times.
Haven't seen the thread mate. Don't really go there anymore.
Posted on: 2013/2/6 8:59
It did it with the old tyres too.
Posted on: 2013/2/6 9:46
Forced Induction!
