Browsing this Thread:
1 Anonymous Users
Re: L18_B110's 120Y 2dr sedan - street/track project |
From sydney australia
Harry, I was taking some bits off an l16 in a Stanza yesterday at Northern Wreckers, but you probably want something closer to home. Maybe a chat to the guys from the QPDC could find you an engine. Was it Ken Graham who used to own Accurate Suspension? He ran a 1600 in hill climbs for many years with 2 or 3 other guys, he might be able to help. I also bought some gearboxes from 2 guys in Brisbane who had bought an old Stanza & were putting an SR20 in it, I could try & find a contact number for them if you want.
Posted on: 2013/3/17 0:33
From Brisbane, Australia
Thanks for the leads Paul. I'll be looking locally first for an engine. And AFAIK Ken still owns Accurate and they definitely still run the 1600 at Mt Cotton etc. Believe he holds the class record.
Posted on: 2013/3/17 4:17
Harry, I'm also looking for an L16. I've decided to go to the darkside. We could have traded carbs for Stanza gearbox :) I'll let you know how I go on my search for a decent engine, where there is one, there is usually two, or three, or four.
Posted on: 2013/3/18 2:37
---1976 B120 "THE GENERAL REE"--- Former build---1980 B120 Vanilla Ice --- current build
welcome to the darkside! Hope this means the ute's no longer up for sale?
Posted on: 2013/3/18 3:11
Harry, I found the number for a fellow called Craig who lives in Port Macquarie, but his brother lives in Brisbane where the car is. They bought an old Stanza they are fitting an SR20 to. Can't guarantee anything, as it's been more than 6 months since I bought the boxes. They might have an L16 but I seem to remember they had an L20B. It's best to try Craig during the day, if I can remember. Good luck with the search, but you might just have to settle for an L20B. Pity I didn't win those 15 inch Simmons on Ebay, I could have got you to pick them up & maybe swap them for an L16 from down here. Still $300 for rims you have to spend another $200 each to make use of, Lucky I was outbid, really. & Is the darkside from how tall they are & the shadows they cast?
Posted on: 2013/3/18 9:27
No it's how dark a series powered owners are on L series powered b series cars
Posted on: 2013/3/18 9:29
Quote: R-fastmotorsport wrote: Hey Harry, good to hear of another Lseries build!! I still have some goodies about the place from the yellow coupe. A87 head with lots of work by Datrally and improved again by Cave Hill in Vic under Errols instruction. Datrats adjustable cam gear etc. Also have 2 close ratio 71B 5 speeds available. Extractors I built to suit the coupe including merge collecter and transition also here. PM me if anything grabs your interest. Cheers mate.
don't know if you got my PMs? I definitely want that cyl head and probably the extractors too thanks mate.
Posted on: 2013/3/19 22:57
Hey Jeff, How much would you want for one of the 71B boxes. Would go nicely behind an L20B with a 76 degree cam in a Sunny coupe. So, Emma Khisit? Paul.
Posted on: 2013/3/21 9:04
picked up an engine... came with a lump of red stuff attached. The L16 idea is out since this Bluebird came up cheap. L20B with electronic ignition, and a set of 14x6 Delta turbo mags in good nick, which is handy because its the recommended size for those semis I bought. Might be able to use some other bits and pieces too
Attach file: IMG_2732_1200.JPG (104.92 KB)
Posted on: 2013/3/30 4:04
Good Score, Harry. Pity you sold the A14, you could have fitted it to the Poobird & sold it as an economy model. Are you going to use the gearbox from it? The 120Y has a neat oval hole in the top that hopefully the longer 71 box shifter lines up with, all you'd have to do is duplicate the oval cover section with the rubber offset backwards.Or is it an Auto. Are you in the market for a Z24 crank next?
Posted on: 2013/3/30 7:31
