« 1 ... 51 52 53 (54) 55 »
Re: Datsunbeginner becomes an expert - Vanilla Ice ute build USA
From Near Bundaberg QLD
Also, I think Chris Lyons (clyons on here?) may have made that manifold, or at least he made some steam pipe ones much like that.
Posted on: 2019/9/29 11:53
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Misellaneous parts acquired.
Found out the hard way there is two different water pumps and fan spacers for the A series. Thanks for Peter Zekert coming to the rescue and later supplying me the right one.
Valve cover paint stripped.
Strut tower plates stripped and painted.
Also found out the USA spec fan belt did not fit.
Posted on: 2019/10/4 2:55
I think you'll find that belt is probably for the early model A12 with the alternator mounted on the manifold side of the engine
Posted on: 2019/10/6 10:41
From Look who's back in town
Move back to brisbane , at least datsun parts shop is there ;)
Posted on: 2019/10/15 1:21
Was B110 Sedan: L series
Now b310 L series
Too expensive to bring my ute back over to the place where it originally came from
Posted on: 2019/10/15 14:00
From Brisbane, Australia
Good to see you powering on with their build!
Posted on: 2019/10/17 11:49
These images are about 6 months old. Almost caught up to present day.
What we have here as some goodies that I brought back with me from my last trip to Australia. Thanks to Chris from Datsun Parts Shop for providing me this replica stickers.
I also test fit my intake and exhaust and found there to be clearance issues. I will need to drill, cut, adjust.
Lastly I took off the flywheel using a homemade bent plate to expose the rear main seal and found that it looked in pretty bad shape and I replaced it. Also the photo with the bolt is a huge success!!!! I was able to clear the broken easy out drill bill, retap the engine block where the old bolt broke off. It was like in the movies where the person is defusing the explosive. I was sweating bullets!
Posted on: 2019/10/31 20:05
From Hawaii, USA
By the way, there is a RH version and a LH version of those. If mixed up they will take some mods to fit
jpg  20190601-123647.jpg (71.15 KB)
174_5dbcb25753f4b.jpg 640X480 px
Posted on: 2019/11/1 22:31
That explains it!
Posted on: 2019/11/3 15:51
Photos of the Exedy heavy duty clutch install the aussies call it "Sports Tuff". Hopefully it will be tuff indeed.
Test fit of the Longchamps. Ran into clearance issues on the front. Wheels hit the front strut. I plan on using longer wheel studs and a hubcentric spacer. 10mm is all I need.
Front and rear brakes REPLACED with japanese fittings. I replaced every single line with a steel brake line with M10 FITTING!!!!! not the 3/8" USA fitting. Still mad about that.
Mishimoto radiator install coming soon.
Posted on: 2019/11/4 3:14
