Re: L20b into 1200 ute
You have a hat? And I just thought you just rubbee your helmet for fun
Posted on: 2013/9/4 11:28
From Gold Coast Queensland, Australia
Thanks for all the valuable info. So the conversion is locked in!
Researching rear axle set ups now. Reckons the h165 is good for 1.8L. Am I going to break it with the 2L?
If i can keep the stock diff and put 3.7 gear ratio in for longer legs my wallet(wife) wont get upset.
Posted on: 2013/9/5 2:14
From Snohomish, WA USA
Stock will work. Just don't lock the rear end.
Posted on: 2013/9/5 19:57
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Geelong, Vic
welded or open h165 will stand up to an L20b perfectly fine, i ran one in my sedan for years before i went to the BW78
Posted on: 2013/9/6 11:47
From Port Douglas. QLD
You could buy my old setup im about to remove ;)
bluebird trx l20b, elec dizzy, 45mm webber
Posted on: 2013/9/9 6:36
1200 ute
ca18det
From Canberra
if you want to use the 200b struts you need either 120y steering knuckles or 200b steering knuckles..
and also the 120y or 200b radius end rods for it to sit correctly
Posted on: 2013/9/9 7:07
Or use 1976-up 1200 ute knuckles and radius rods (and LCA).
Posted on: 2013/9/9 7:30
Is the stumpy up for grabs mrbarista?
Got 200b knuckles, rods and discs. Gonna stick with the stock diff for nowCheers for the knowledge
Am I gonna need deep dish wheels on the rear to match the offset created with the 200b struts?
Posted on: 2013/9/9 21:56
No, definitely not deep dish. But you may want to get wheels with less offset for the rears. The 810(200B) struts add 25mm to the front track. Better yet get 1/2" wider wheels and 20mm wider tyres for the rear.
Posted on: 2013/9/10 3:24
No the stumpy is going behind my ca....for the meantime
Posted on: 2013/9/10 11:45
1200 ute
ca18det
« 1 (2)
