Strut swap for b110
From Trinidad and tobago
My situation.
I did s13 brakes conversion on the 120y struts,my wheels didn't fit because i have 13" rims now i wanna put 910/180b struts in the 1200 an i wasn't sure if i can keep the b110 lca and put b310 knuckle arm an balljoints to accept the 910 struts,any heads up?
Posted on: 2013/9/17 22:11
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Strut swap for b110
The B310 balljoints won't bolt onto a B110 LCA. What is needed is a B310 LCA which is exactly the same as a B110 LCA except for balljoint and caster rod bolt patterns. See SAP.
Why not put the S13 brakes onto the 1200 struts? See S13 Brakes.
Posted on: 2013/9/17 22:30
I did put s13 brakes on but i need 14's or 15 rims,what about the spring perch do i need to put the ones fron the 1200 to the 910 struts or just my spring and top hat?
Posted on: 2013/9/17 23:18
Street Sleeper!
Why use the 910 struts? The B110 struts will work with S13 brakes and 14 or 15" wheels.
Yes, the 910 struts need a spring perch to fit your springs.
Posted on: 2013/9/18 1:07
