Browsing this Thread:
1 Anonymous Users
H81 head what comp is std ? |
From melbourne
Hi guys, I have just started to strip the spare engine A12 the markings on the head say H81 /073 i've been told this is a sweden emission head,The whole motor is from a sunny ute ,small port,intake 35mm exhaust 29mm "what comp" would this head produce on a stock A12 engine..? thanks Anthony
Posted on: 2014/1/18 9:26
Re: H81 head what comp is std ? |
Registered Users Contentmaster Usermaster
Should be the typical compression ratio - 8.5:1. Good for std octane fuel.
The SWE head was used in many places but apparently not in Japan.
Posted on: 2014/1/18 9:57
From melbourne
ok so my 120y should be std comp of 9.0-1 this head will drop it further down to 8.5-1 ? cheers anthony
Posted on: 2014/1/18 10:01
If it does you won't notice the difference. 1/2 point CR is only 1 HP difference.
Posted on: 2014/1/18 10:05
From melbourne
your right but helps when calculating/playing with final boost pressures thanks for your help cheers anthony
Posted on: 2014/1/18 10:11
E85 Turbo 120y wagon Built not bought........
