Sticky Gear from 4th to Any
From Sri Lanka
Hi Guys
I have a small problem with my b310 , if i stop the car completely on 4th gear most of the time the gear is sticky, can't move to any other gear unless i move the car to front or behind , what would be the reasons ?
thanks
regards
sumith
Posted on: 2014/4/21 8:04
Re: Sticky Gear from 4th to Any
Time to check the clutch adjustment. There should be about 25 mm play at the clutch pedal, or shifting can become difficult.
The other cause of this problem requires partial disassembly of the transmission. So first check the play. Press the clutch pedal with the smallest finger of your hand. How far does the pedal move?
Posted on: 2014/4/21 13:54
From Sri Lanka
Hi DD
Thanks. i will check it soon, Car is on a hill country journey these days, when i come back to colombo i will check it back, First time i put my datto to local highway cruised around 80 kmph with no fuss ,so far it has done me 15 kmpl on average driving , happy motoring
thanks
regards
sumith
Posted on: 2014/4/24 4:23
Hi Sumith. Happy Driving. Checking takes no tools, you can check it now if there is no play, a long drive will ruin the clutch.
Posted on: 2014/4/24 7:58
From Sri Lanka
Hi DD
Ok i will as soon as possible, Probably on Saturday, till that i will not be going out
thanks
regards
sumith
Posted on: 2014/4/24 11:11
