A14 or A15?
From Sydney
Hi guys I'm thinking of getting an A series built to suit turbo. I have a mild A14 currently which I'm thinking of leaving complete and starting over fresh. Question is, what should I use as a base A14 or A15? A15 has more capacity, and most likely more torque aswell. Can anyone advise on which they think is the better base option.
Iv got a h75 head ready and no bottom end, but I know of a short motor A15 for sale for $350
If this goes ahead, I want to build it once and make sure the money is going into the right motor
Thanks in advance
Posted on: 2014/5/16 14:31
Re: A14 or A15?
From Malaysia
if you have the option, go for A15. no replacement for displacement
Posted on: 2014/5/16 15:42
Re: A14 or A15?
A14 makes a good budget motor, otherwise go for the cubic centimeters.
Posted on: 2014/5/16 20:19
Re: A14 or A15?
From sydney australia
For a street motor, the A15, for all out race motor, it's not much different,as it comes down to how much you can get into the cylinder, rather than the capacity of the cylinder.
You've already found an A15, so in my opinion, you should use that motor. Leave it at it's standard bore for maximum strength, as well.
Posted on: 2014/5/17 0:57
Re: A14 or A15?
From Sydney
Sounds like the a15 is getting a lot of thumbs up. Next thing is to save up for forged pistons!
Posted on: 2014/5/17 9:15
Re: A14 or A15?
Forgies! Nice, you planning on some big power DJ?
Posted on: 2014/5/17 22:58
Re: A14 or A15?
From Sydney, Australia
In NSW a14 doesnt need engineers certificate. a15 does.
Posted on: 2014/5/17 23:05
Re: A14 or A15?
From Brisbane Qld
What would be a good Budget of A14 rebuild if the Head was already done?
Posted on: 2014/5/17 23:20
Re: A14 or A15?
$200 for gaskets, rings, and bearings.
But for Turbo application, add the cost of forged pistons.
Posted on: 2014/5/18 2:27
Re: A14 or A15?
From Perth
A14 is what I'm using for my turbo build
1mm over to 77 making it 77mm bore x 77mm stroke
My engine builder likes the square dimension idea for this build
Posted on: 2014/5/18 5:00
