Auto Gearbox
I have lost some fluids from the auto box. How do I test the level with or without the engine running?
Posted on: 2014/9/5 14:00
Re: Auto Gearbox
From Lisboa-Portugal
Hello, the level must be checked with the engine running at normal temperature.
Posted on: 2014/9/6 13:50
Re: Auto Gearbox
Many thanks for that. Is there any procedure I need to do to check this level or just run it on level ground.
What is the correct fluid to use?
Posted on: 2014/9/6 14:03
Re: Auto Gearbox
From vic
Level ground is best for proper readings
If its a datsun auto your talking about use dexron 3
Posted on: 2014/9/7 1:48
Re: Auto Gearbox
Ok thanks I will go and look for some but as I'm in Thailand it may have a different name or brand name?
Posted on: 2014/9/7 3:38
Re: Auto Gearbox
From vic
dexron is not realy a brand its just a specific type of atf they can come in many brands Just ask for dexron 3 atf and they should know what your talking about.
Posted on: 2014/9/7 7:57
