Browsing this Thread:
1 Anonymous Users
Strengthining clutch assemblely? |
From Narellan,Sydney
Hey what have you guys done to strengthen the clutch pedal assemblely? Iv got a heavy clutch behind the 13b and after a bit of driving it starts to loose clutch.pedal itself is super strong.not exactly sure were the problem is
Posted on: 2014/11/18 6:38
All stainless steel-mild steel Sheetmetal and tube work All types of welding Custom metal polishing BSA custom fabrication 0415 904 474
Re: Strengthining clutch assemblely? |
Hydraulic set up?
Posted on: 2014/11/18 7:40
Yea mate sorry forgot to mention that
Posted on: 2014/11/18 10:13
From Brisbane
Hydraulic fluid over heating maybe?
Posted on: 2014/11/18 10:42
Air in system when hot expanding maybe. I agree sounds heat related
Posted on: 2014/11/18 10:44
From Malaysia
make sure the firewall doesnt flex when you clutch. saw more than once, the firewall become softer when it's hot, it flex when clutching.
Posted on: 2014/11/18 14:52
No it's not heat related.no master isn't on the firewall it's reverse mounted on the steering coloum.i think it may be the slave leaking a little bit.will double check it today
Posted on: 2014/11/18 20:50
From Gold Coast Queensland, Australia
You can use a bracket to fix the clutch pedal assembly to the firewall or steering column brace. worked for me.
Posted on: 2014/11/21 5:07
1200 ute L20b
Every thing was already braced up and strong.turns out the clutch master was stuffed.put a new 1 in and it's never felt better.back tearing up the streets
Posted on: 2014/11/28 9:26
