clutch and flywheel bolts
From Christchurch NZ
okay,
here's some dumbass newbie questions for the masses.
The clutch cover plate bolts are M8, but how long should they be?
Also, what diameter, and thread are the flywheel bolts? I knoiw that the bolts for a front dizzy crank are imperial, but these are for a mid dizzy engine.
I have a small window to scoot off to a fastener shop tomorrow morning. and family commitments mean I don't have the time to find these answers for myself......
Posted on: 2015/4/3 11:32
Forced Induction!
Re: clutch and flywheel bolts
The bolt shop was closed today.
So I sifted through lots of ice cream containers of bolts, and found some old flywheel bolts. and I found some clutch bolts too.
Posted on: 2015/4/4 9:24
Forced Induction!
Good, cause flywheel bolts have a special ground head.
* front dizzy A12 have 3/8" x 24 bolts
* mid dizzy A12 have 10mm bolts
Posted on: 2015/4/4 9:29
CLUTCH COVER BOLTS
* Same as L20B, Z-series, SD-series, E-series, CA-series
* 30223-E4100 SCREW-cap. clutch cover to flywheel (6) $4.87 USD
* 08915-23810 WASHER-lock
Posted on: 2015/4/4 9:38
