#1 Top gear lsd
mrbarista Posted on: 2015/4/6 10:38
top gear lsd'a
Who's running one??
#2 Re: Top gear lsd
zigmondo Posted on: 2015/4/9 9:31
Just Got mine fitted to a 4.1 ute center, going into a bluebird housing, fitted into a Clubman 7 will let you know in a couple of weeks :)
#3 Re: Top gear lsd
1200rallycar Posted on: 2015/4/10 1:31
got one in a h190 and one in a 165
165 in rally car is amazing (A14, twin SU's)
190 for hill climb/bitumen stuff is amazing (CA18DET - standard)
only fault - which is a nature of torsen is if you lift a wheel it can single spin that wheel
i've only ever noticed that at a particular hill climb which is super tight and heavily cambered, if i deliberately used compression lock up into 2nd gear to really throw the car it would unload the inside wheel enough to lose drive (spin up the lifted wheel)... but in that scenario im really just having fun throwing the car as hard as possible and not actually driving for speed so its not a real concern
in the scenario of having an oops in the rally car and being stuck in mud digging holes off the side of the track it was actually still spinning up both wheels , so it seems to need a pretty extreme situation to single spin
both cars are 1000% more awesome to drive with the torsen in.
rally car is so much more drivable/controllable/predictable than when i had an old sprung load (phantom grip)
the road car is also a lot more predictable and can do awesome LSD style powerslides, it also hooks up awesome on launches
