WTB- fiberglass dash- 1200/b110
From tassie
hey guys, just wondering if anyone sells, or knows of anyone that sells a fiberglass dash for a 1200/b110
cheers in advance!
-thewaggs
Posted on: 2015/5/27 9:23
Re: WTB- fiberglass dash- 1200/b110
From RSA
hi why dont u try making your own.I made my own boot-lid just followed that Ozzie old man on youtube [Redline].I use the woven cos it's less of a mess. 1st wax [cobra floor wax will do] 2ndrelease agent 3rd gelcoat -- thats your mould OR pull your dash --use cardboard to get top shape --use wood [cant remember the name] like thick h/board --flat sides are ok but dont try bending it will lift --one piece for top and 1 piece for the drop --make it wider --can always cut back with dremel-- cos ur mounts are 2 screws on top and 2+2 on the sides or is that 1+1 -- I do it the lazy way and just use the mould --then u got smooth side inside --then i smooth the outside with sanding machine [not good for machine -dust]use gelcoat and sand again --actually more work. Use 450g woven works great --watch y/tube redline f/glass body parts for real thing
Posted on: 2015/5/27 18:52
From RSA
sorry gelcoat then 1 layer f/g then 2nd layer - check y/tube for correct procedure
Posted on: 2015/5/27 18:55
From Gold Coast
My brother in law has one, he wanted $300 he's on the Gold Coast
Posted on: 2015/5/27 21:44
From Gold Coast
Posted on: 2015/5/27 21:45
From Vic, Australia.
If you were going to try to make your own look up soundmanca on YouTube he's making kick panels at the moment but the method would be the same and work well, basically making flexible sheets of fibreglass out of thin sheets that are hardened then gluing them all together to get a shape then reinforcing with more layers.
Posted on: 2015/5/28 2:47
